Hey all,
I have done some research and can not seem to find the problems I have encountered (or its under something else) on the weekend I finally go around to putting in my new distributor (recorrected the timing, and fix the leak the old one had) and since putting it in I have found that it takes a few a little bit to get up and go maybe like 1500-2000RPM before its back to its old self? I have disconnected my Tacho (aftermarket) since doing this so I am unsure of the idle speed.
Second of all, my fuel gauge was working fine on the way home this evening then pulled into a street a few blocks from mine to notice the Fuel Gauge was not reading -.- I read some where that its possibly the sender? there is a fault or something
Any help I can get will be much appreciated
