faster pull away
if i put the 1.0l k11 gearbox in my 1.3 super s would it give me better acselartion and would it be a easy swap as ive got the 1.0l gear box over is it a easy swap would i still be able to use the 1.3l clutch or are the gear ratios the same alkl the best lance
ideally you need the post 2000 (14" wheel) 1.0 g/box lance, my pre98 1.0 box is slightly lower geared than yours but the flywheel, clutch, shafts etc are smaller/lighter :)
