Hi guys. Just bought a 1.0 k11. The gearbox is noisey. The oil has been changed and it's still noisey. It's not too bad at the mo but sometime soon I think it's going to give up. So I'm after a low mileage manual box if anyone has one thanks,
Yeah as soon as I push the clutch down it dissapears.
^ Clutch Release bearing if it goes when you press the clutch down. Mines does that
it should,nt be spinning/making contact when the clutch is up really mate (and as a result noiseless)Though it was the clutch release bearing if it disappears when you push the clutch pedal down frank no?
because when you push the clutch down to select 1st gear the gear clusters stop spinning, and no noise then would indicate shaft bearingsand is it noisy while moving ?
?if its that coilpack k11 you mentioned steve ? then its a different g/box to the pre 2000 ones btw
Hi mate yeah it's a 2002 and it's got a coil pack, the noise is always there when driving except between gear changesif its that coilpack k11 you mentioned steve ? then its a different g/box to the pre 2000 ones btw
It was happen to mine. I sent to mr clutch auto centre so they changed new clutch kit. It's two years on so it's not good now lol.
Clutch shouldn't wear out in 2 years JK?
