I was told to get facelift manifold and rail to fit my top feed sr20 injectors? What do i need?
the rail mounting holes are in the right place, you just need some collars in the injector rubbers (i used short lengths of 15mm copper tube) but the rail hits the idle control valve tho,
options are to remove the icv and mount it remotely, my preferred option was to run without one
you could fit a cop mani and t/b, but the wiring and sensors are very different tho
yehIs the collar to hold Injector in situ ?
