Im selling now my cg13de, engine includes;
-gsx-r ITB, custom manifold, 8x 270cc injectors, FPR, air filter etc.
-head have been port and polished, 280/9,6 camshafts, catcams valve springs
-bottom end has 1.0 pistons and new headgasket (something like 11.7 compression rate)
-distributor modded for megasquirt
-cg10de damper
i have also if needed, stock flywheel and clutch
500gbp + shipment
-megasquirt 1 v2.2 with ignition driver, tuned for this setup and re85 (125bhp) some universal loom and connectors.(easy to wire up)
selling only with engine 50gbp
exhaust manifold, bottom bracket need to be modified if like to use this
sellin only with engine 50gbp
so, 600gbp and shipment and u get 125bhp micra engine with rought idle and high gas comsuption.
This is same engine as in my project topic : https://www.micra.org.uk/threads/newbie-with-cg13de-real-tuning.65600/
easy to access more power with new exhaust header and intake trumpets.
If u dont need block, i can sell only head or head + pistons and rods for cheaper postages and -50gbp from engine price. Then postage will be under 150gbp
IN FINLAND!
-cg10de damper
500gbp + shipment
IN FINLAND!
