extractors and alternater
CMF_33driver
only need to space out the top bracket, just the two bolts (i spaced out the mounting bracket from where it mounts to the engine block)
the bottom should pivot (may need to loosen the bolt a little to make it move, but no spacing is required).
You should be able to reuse the same belt too. Let me know how you go, I'll try and take some pics tomorrow, working long hour atm to lighting sucks :p
