hi
i've just bought a 1.0 twister, as my first car, however it doesnt have, a rev counter, electric windows or front spots. i was jus wondering if it is possible to get these for a micra, and if so would i be able to put them in mine?
Yes it is possible. You need the rev counters from either a super s or a sr. These will fit although you might need to wire in a cable from the dizzy to the clocks. As for electric windows either get the motors and door cards from a scrappy or get a kit of egay.
As for the spots,the plug should already be there so its a case of buying the spots, fitting them and plugging them in. Dont forget also you might need to wire them up to a switch or get the actuallstalk from a scrappy.
If you ever get stuck theres plentlyof people on here and also check out peoples blogs
R reg,1997 was when they were facelifted.If yours is a late in the year car it may well be a facelift.
Pic 1.pre facelift
pic 2.Facelift
If you must have electric windows don't bother with those aftermarket kits,very nasty
