Exhaust Question!
So basically the weather has been to rotten lately I havent had a chance to look, but what I want to know is does my 2002 coilpack have a second silencer/cat that is removable without chopping it out? Ideally I'd like to replace it with a straight through bolt in pipe if such a thing exists?
The trouble with the coilpack's is the ecu does a great job at keeping the engine power the same even after mods. If you put a performance exhaust on and also a performance air filter setup, then the ecu has trouble with the fueling and runs lean. The almera/primera Airbox mod is a nice mod on this engine. Gives a nice sound and improves response.
One of the first mods I did was the GA aibox alright if that's the case and its gonna mess with the fuelling I may just leave it be, it pretty uneconomical already can't afford to make it worse
the coilpack mid pipe is longer (to account for the 2nd cat delete) and some makes/brands of mid pipe dont have the welded silencer included (i bought a copy one years ago in order to delete my 2nd cat, and it was just a continous pipe)
the coilpack (post 2000) mid pipe is longer than pre 2000 mate
so you can fit the early midpipe + decat, or else fit a copy (or coilpack 1.0 ?) non-silencer later mid pipe
Drat and there i was thinking id found the right pipe....seemingly impossible to find for a coilpack, might just look into getting one made up...
