trying to remove the heat shield (or as it is known in haynes hot air shroud) from the exhaust manifold so i can sand it down and paint it as it is quite rusty/blemished, but i cant get the nut which attaches the support bracket to the shield (and then the manifold i think off) as the nut is a pentagonal shaped head so ratchet bits dont fit on it....unless a hammer is used but the straight head is only about 2mm deep, after that the head is bevelled outwards so the ratchet bit wont go on anymore and it just either falls off or wont stay on in the first place.
i have the haynes manual page incase you dont know which bit i mean, haynes k11 93-02 page 4A-13 bottom right No: 16 - Exhaust manifold - removal & refitting.
please can someone help, i have tried using a wire brush incase the bevelled bit was rust, but all i have now is a shiny bolt which is still bevelled.
stew
stew
