Exhaust 1.3
Can I just pick your heads a min?
We have to run the standard manifold so not good !!! But we have a straight pipe from the cat back but the box we have has no baffle! Would this effect the performance? Do these engines rely on back pressure? Thanks
So do
nah, backpressure on a 4 stroke is a myth
What do you think is best to do at the moment I have the standard manifold with the cat on the down pipe then a small box with no insides. I have emptied the cat. The exhaust stops just under the front foot wells just Incase he takes a hit!!
you need an optimum gasflow/exhaust speed and minimum restriction steve, the system needs to be small enough dia to keep it flowing at speed (for extraction) but big and straight enough to limit restriction/backpressure
the stock downpipe is quite puny, so that is your limitation really :)
