Hello all!
I've got an issue and it bothers me a bit... if someone can shed a light on the matter would be great.
The Micra I daily drive has now 43000 kms and I had in mind to change the brake pads at 45000 service to something better like the EBC Ultimax or Green Stuff.
Prior ordering anything I just had a look between the wheels spokes to the situation of the current brake pads and these looked all right (still original since I bought the car new 3 years ago). The situation of the brake pads is ok probably because the last 25000 kms were mostly highway without much braking involved.
What intrigued me was that the right side rotor (driver's side) was wear a bit more than the left side. The wear is not substantial but enough to annoy me. Another issue that I've encountered was that on braking the right side front brake makes a squeal sound which is pretty predominant.
Can it be the case where the right brake pad was made of a different material then the left one or not mixed properly at the factory therefore causing this issue? Also will this excessive wear on one side will affect braking performance in future? Will it be better to order new brake rotors and pads in order to avoid any issues?
Looking forward for your thoughts,
Adrian
Adrian
