evade got 110kw/150bhp at the wheels
CMF_evade
went to a dyno day on the weekend for some fun.
boost was set to 10psi, and got 110kw pretty happy about that!
at 7psi, it power was 92kw.
Heres a video:
scan of dyno graph here:
http://aa.wh3rd.net/photogallery.php?photo=993
noticed it was running pretty lean across the map, despite not having touched the map since the last dyno (which mixtures were fine) so im thinking either injectors or fuel filter..i changed the fuel filter today, and will get another afr check to make sure all is running OK.
cisco
****e! Congrats mate. That is massive for 10psi. Well done.
smidge
it's all good mate we can learn from your mistakes :D
i'm keen to sue the same management you did, so no glad you're still around so we can pump you for information!
