CMF_fred
» CMF MemberWell, I've broken ground on my new garage/workshop for the EV build.... Evee(for what of a better name), is currently under tarp in the yard, until I've got flat dry ground to work in...anyway, I'm currently researching final technical specifications of the EV install.
Externally, I will be aiming for a WRC tarmac rally car look if that's a look that describes it.
Internally/mechanically, Lithium ion/polymer batteries, Ultra capacitors, Ac Induction motor rated at 60/150kW (120/300Nm torque).... EXA RS531V gearbox. no clutch. approx range of 200km.. Performance aim is 0-100km in 6second region.
whiteline suspension bits with the exception of G4 or other coilovers. Wheels/tyres not sure of depends of cost/performance(happy with 15's but interested in wide 13 or 14's). Brakes will be GTIR rotors and calipers plus engine regen using old clutch pedal(prob only need pulsar but I like brakes)
Interior, Gloss Black with brushed Aluminum parts(handles,knobs, levers, etc)...2 seater (deep racing buckets)set back a bit, Cargo cage that on closer inspection will improve chasis strength. Instrument binnacle to have acewell speedo with EV dash via palm pilot
For fun, I want to retain what appears to be a muffler/exhaust but will actually be a speaker network, which the driver can choose what the car sounds like......or not.
Any input anyone? Glad to hear your Ideas
