Hi
I live in Sweden and have some problems with my Micra. It is probably the timing chain since it got the typical P0340 fault code and problem to start.
Since the timing chain change is so expensive i thinking of change the whole engine. Here in Sweden I can get a used engine much cheaper than the timing chain change would cost.
There is just one problem. Most engines out are type CR12DE but according to my dealer mine engine is CG12DE. Anyone knows what the different are between this engines? Can i use CR12DE?
Best regards,
Peder
Best regards,
Peder
