imp124
Buy & Sell Member
Hi, im having some teething problems with the idle on the ST.
If it start the car in PARK from cold the engine will idle 900 - 1000rpm fine
I put into drive still about 1000 rpm
i drive for a bit and the engine gets up to normal temperature, if i leave it in gear it idles 900 - 1000rpm
if i take it out of drive into NEUTRAL or PARK the idle now reaches 1800 - 1900rpm?
If i adjust the idle now when hot on the far right had screw on the TB it will then idle fine but cut out when cold, the middle screw on the TB i cannot see doing anything when movedn (currently 1 1/2 turns out)
any help?
Steve
any help?
Steve
