The Micra 1.3 Or 1.4. Easy swap And not much to do with wiring Or welding.
I am confrunted with an issue - I had a 1997 1.0 dizzy, I dropped in the 2001 1.4 coilpack. Engine, gearbox, accesories, everything. The problem is the wiring is very different and the connectors/pins don't match:
1997 1.0 (old) - 2001 1.4 (new)
Left hand drive - right hand drive
2 connectors on engine relay box - 3 connectors on engine relay box
big 50x70mm connector in fire panel (~30 wires) - 2 connectors in fire panel (~20 wires)
I am not sure how to go about and adapt these. I'm thinking at 3 variants:
1. keep original wiring all the way to the engine, add missing wires if any, cut connectors there and replace with old ones
2. also replace the wiring leading through the fender, inside the car, splice stuff there
3. move ALL the wiring harness from the RHD car to the LHD car, shorten/loop the cables(cluster, fusebox are now closer to the cable entry point ), lenghten the ones that are too short
Can you please advise as to how would you go about swaping a 1.4 coilpack in a 1.0 dizzy?
Thank you
