Engine swap
Ok lads im getting ready for an engine swap finaly, mines a k11 1L 2001, myself and my mates going to put a 1.5L perrol out of the older almeras 1996, they say its a straight swap as they use the same block just bolt in job and swap over the ecu amd wiring loom, is that true? Any tips or advice be greatly appreciated
I could be wrong but I imagine you will need the drive shafts aswell? As I know you do on the sr20 which is of similar age
Ya its just the hassle of finding a 1.4 micra engine here in ireland there as rare so they are,
Your saying best bet is to find s 1.3/1.4 micra engine n put that in?
That would be best bet, failing the sr20 with a fair bit of modifying to get it in, the sr20 is by far the most powerful swap
