all you need is to open the drivers side mount up abit and the engine bolts to the back mount and drivers side then with the gearbox it sits about 20mm over make up a set of triangular plates and redrill the hole for mounting. once this is done the engine and gearbox is mounted. none of the chassi leg needs cut and no pullys catch. you need custom drive shafts but i might have a solution for that as mine are just sleeved and welded atm. after this is all done connect all piping back up and nearly everything plugs in. change the ecu to a none nats 1.6 ecu and fill all liquids u have a 1.6 micra well thats nearly whats all to it cant tell you everything
