Engine Swap help
h701micra
Deactivated Account
Read all over the site about engine swaps and im now taking on a project myself
Like others i'm on a tight budget (for now).. but i've managed to get hold of a nissan 100nx 1.6..
So will be using the ga16de i believe (its a j-reg)
The bit i need help with... I havent heard of anyone use an nx only primeras and sunnys etc unless ive totally missed something. But its the engine mounting problem.
Ive read about the p10 mounts being taken off and used with some cutting and grinding. Can i use the 100nx mounts? Are they the same?
Any other info you have to help me get this engine in would be appreciated
Will start a blog as soon as things get moving so i can share my progress
Will do :)
Will it b the same sort of job as the other ga16 conversion?
Meaning... Cut and weld in similar places?
