Hi all,
SWMBO's car (1.0 K11 2001) is dripping oil from the sump, I can see quite a bit of corrosion on it, so I guess the pan needs replacing. Do I need to remove the exhaust to change the sump ? I only ask as the exhaust bolts are really rusty and I don't fancy having to drill and tap new threads etc. You're advice would be greatly appreciated
