This is a K10 engine with AT - no mods, just a standard set up.
Symptoms: will start from cold first crank no problem, warms up with fast idle correctly and settles dwon to correct idle speed. Then... after a while (time seems to vary) the egnie speed drops to around 250/350 rpm and then stalls if the throttle is opened! After which, further attmpts to start the engine result in stalling after a few seconds of immediately if the throttle is opened.
Have checked all the vacuum hoses thoroughly and replaced all the brittle and perished ones. Checked the timing and mixture - they are as per spec. Checked the spark plugs and they are all fine, apart from showing a little rich running. Checked the electric choke - all works fine.
Hmm... now at a loss! I have other similar threads, but they do not seem to help.
Any suggestions would be VERY welcome
