Hi all,
I have a 2000 k11 gx 1.0l - she's run like a dream up until the last 12 months or so. I now find that when the car starts and is running in idle, the rev counter bobs up and down randomnly (by maybe quarter of a 1000 at min and max), and the chassis itself vibrates. Not much mind, but enough to get a bit sickening after a few minutes! I've also found that when driving, coming up to stops and roundabouts she gets very hesitant, almost as if to stall but not quite. The final piece of this puzzle is that when I'm accelerating out on a motorway up through the gears, the initial change into fourth gear causes the engine itself to hesitate for a second before accellerating again. Also while accellerating through fourth, a particular feint noise (almost like gas releasing) can be heard when throttle is applied. This only seems to happen in fourth gear.
My last car service helped a tiny bit with the above problems, but not much. I'm thinking now that maybe I should try a local Nissan service dealer, as when I called them up the guy mentioned "resetting the idle". I'm sad to say I'm only learning about all this stuff, so I've no idea where to start on diagnosing and then fixing these problems.
Can anyone help?
Thanks,
Aengus
Can anyone help?
Thanks,
Aengus
