Does it rattle only at certain revvs? I can't hear anything on the video but I am suspecting a loose heatshield?
inside vid is done now so i am waiting for outside vid to be done soonJust post them up here when they're done
lol, that subframe/crossmember has detached completely eh jk ! so the rubber mounts at the rear of it will be metal to metal (and causing vibration)
you will just need new rubbers and nylon inserts jk, they will probably be worn away now because the weight of the engine pushes the frame forwards without the front bolts holding it in placeSo it's been like 2 months now. Is my engine mount getting already damaged yea? All I need is to change new front panel and lower cross member. Do I need to get new engine mount? Please can you advise me thanks
water pump bearing done up ?
is it? well i need to check it out. how do i know if my water pump bearing gone?
i had one squeek like that noise, any water under the pump?
R-REG-SR said:water pump squeek , loose chains ? and some mud flung on top mud mun
R-REG-SR said:my chains rattle until warm or tensioner starts working? then smooths down. i think its normal
is you engine smoking ?
low oil might not help
Its not the chains anyway. Try getting a new alternator belt first. Sometimes they just get squeaky with age, the rubber goes hard and perishes. Chances are its still the original belt and well past its best.When you have the belt off, start the engine briefly and if the noise is gone then you are on the right track. Spin the water pump by hand and listen/ feel for anything odd. do the same for the alternator. If they feel ok then put the new belt on. DO NOT overtighten the belt, you will certainly kill the water pump bearings that way
