Belly93 to turbo or new lump :/ hmmm Aug 21, 2012 #1 Is there any difference between the cg10 and cga3 heads? And are the cg10. and cga3 piston rings the same?
frank Club Member Aug 22, 2012 #2 The coilpack cg10 is the same as cga head, and the cga bore is 1mm bigger belly
