Hi
Having a problem with my Nissan Micra Vibe (51 Plate). I topped up the radiator with coolant (as id not done it for a while) - about 50/50 water to coolant. I took the car out for a 10 min drive and when i came back i heard some spurting and it sounded like the engine fan was going (more so than normal). The engine itself felt very warm to the touch (is that normal for a short drive!?)
I may have some technical terms above wrong as i'm not that knowledgeable!
Prior mail for reference:
http://www.micra.org.uk/threads/39658-Nissan-Micra-Engine-bay-picture
The other minor problem i have is that after filling the washer reservoir it appeared to mostly leak out - whilst i was stood there - yet you look in the reservoir and you can see a certain amount of fluid in the bottom. Might this mean there is a hole in the reservoir, but half way up!!!??
Advice very much appreciated.
