Engine mounts
CMF_Yom
I think I've done a pretty good job of it!
Mystery noises while cornering are now explained.
Engine moves back and forward around 2cm when starting. Haha.
The fun part now is replacing the others - something else has caused this particular mount to give way I suspect
CMF_Nissanmania
My engine mounts are knackered as well - only just found out when took old engine out. Pretty much assume any K11 with original mounts and over 100K is likely to have mounts that need replacing.
CMF_SSUK
My engine mounts were in very bad shape when I came to replacing them with Nismo ones. You could rock the engine back and forth with your hands.
I recommend Nismo replacements, the engine hardly moves and gives a very responsive feel when coming on and off throttle. They do transmit a lot more vibration through the car initially though, but after a while they do settle in and this is less of a problem.
Hope you get it sorted Yom :)
