Got a 1.5dci k12. When I start the car up and drive for about 10 mins or so everything is fine, I can put the accelerator down quite hard and it will pull quite well. But then after that if I do the same the red engine management light comes on the dashboard and a message on the radio display saying engine system fault if I ease off the accelerator the light turns off.
It will only let me get up to about 3000rpm then it won't go past that and stays at that speed, then the light comes on. Any ideas Thanks Stu?
