Engine management light
Hi all, went to my k11 1.0 2000 model this morning and it wouldn't start, orange engine light was flashing. I pulled out the fuses for ecu to check if they had blown, bit of a wild guess, they hadn't, when I replaced them the car started and runs fine...... Either a loose fuse / bad connection, or it reset something. Just thought I'd post this as it might help someone else
When you disconnect the ecu, it resets everything. See if the problem returns in a couple of hundred miles. If it does, it would be good if you could read the fault code.
