Engine management light and PS light
Hi
I've just bought my daughter a 2004 micra 1.0 e. It seems to run fine apart from a couple of issues.
First is PS light is on and car has no power steering, can I get a steering motor from another car fit it and have code reset, or is it not that simple.
Secondly engine management light is on and code I'm getting is P0171, its using a lot of fuel and failed emissions test as was extremely high. Any idea where to start looking for fault, map sensor or lambda sensors maybe?
Thanks in advance
PS can be turn off by using N607 Nissan consult II copy tool ease the fault code on the power steering ECU, than power steering will came back if it's not actual parts fail on PS column.
I think you can swap steering motor with same model work straightaway no recoding needed, as motor itself doesn't involve in EPS management system.
