Hi, I'm a Newbie. This car has 2 issues.
Issue 1) About every 6 months, it it sailing along nicely for at least 1/2 an hour, then the engine cuts out suddenly and completely and will not restart. The last time it happened I changed the Temperature Sensor for one with the correct value and thought I'd cured it - wrong!!! The thing that confuses me is that such a 'catastrophic event' brings up no fault codes. Does this suggest the issue is with the ECU - if the ECU fails then it does not record a fault or Mil? A friend who knows more about Motronics than me, said it could be lots of minor non-Mil events accumulating over about the 6 months which cause the ECU to shut down the motor - could this be what is happening ?
Issue 2) It sometimes will not start unless I squirt petrol on the air filter and replace the cover. After that its fine.
Any advice gratefully received.
