CMF_Alex_B
» CMF MemberWell, i got bored so i tested the compression on the micra, following the procedure given in the haynes.
Results were:
1 - 210psi
2 - 205psi
3 - 210psi
4 - 210psi
Now the haynes says standard 13 bars / 190psi, minimum 11 bars / 160psi
Can somebody check in their nissan book to compare with haynes that 190/160 is correct?
Motor has done 147K, checked records car still has orignal motor.
i think the likely explaination is that my compression tester is out of calibration, its just a push-on type,
Alex
Results were:
1 - 210psi
2 - 205psi
3 - 210psi
4 - 210psi
Alex
