Engine change on a K10
Ive got another engine off nexxussteve for my K10, my car is an 84 where as the engine ive got is out of a 1991/92 car, i'm assuming its electronic ignition?
I can get the engine in easy enough but there a couple of plugs, one on the gearbox and one next to the oil filter that I have no idea what they are for. How easy will it be getting it running??
Thanks.
you don't need all plugs. the 84 hasn't even an ecu ;) (ok the thing in the facelift can't be called ecu too) but normally all the plugs belong to the carb, so I would use the old carb if you still got it
