CMF_fuzzy-hair-man
» CMF MemberHi All,
As some of you might remember I am doing a CG13DE in a Morris Mini Deluxe, the conversion is going slowly but well and the front subframe is almost finalized.
Anyway I am putting a mulholland replica inlet manifold on my engine as it will help me clear the firewall and I figure it should help me realize some good performance, additionally I will be getting some extractors made to fit the engine as again the standard exhaust is restrictive and likely won't fit the car. (If it helps anyone the inlet manifold you're looking for is from a 4EFTE turbo starlet import engine or a 5EFHE which is a high compression version of the engine found in some Toyota Paseos, you might find these in Australia)
Here's some pictures and a thread, it took me ages to work out what car the manifold came from...
http://board.tercelonline.com/viewthread.php?action=printable&tid=23606
So given I'm doing the above mods I figure I'll probably need an adjustable fuel pressure regulator to be able to tune to the changed inlet and exhaust.
The question becomes, because I am getting the conversion engineered and I am changing the inlet and exhaust tracts I have to get it emissions tested. So I'm inclined to do all the engine mods I might want and get them engineered so I will have no hassles later on. (probably less cams)
So do I put on a GA15 or GA16? throttle body rather than making the inlet manifold up for the CG13DE item and then possibly have to change it later. Assuming I can get a GA15 tb for a decent price it doesn't seem too much hassle.
So the second half of this question is will I need to change injectors, engine management etc keeping in mind I have to get this thing to pass an emissions test and I will need to get it tuned to ensure it passes. So how tricky is it likely to be to get an engine with a GA15 / GA16 to pass emissions, the Cat will be selected to pass the emissions test BTW.
I want this engine to be a strong NA engine with strong torque in the low and mid rev range. Funnily the 5EFHE tb is 45mm same as the CG13DE a little strange for a 1.5 litre motor isn't it?
Sorry for the very long post.
Any advice guys?
Any advice guys?
