Hi,
Am new to the forum.
A friend has a 03 Micra, which is showing the all too common loss of power steering.
I am aware that the fault code can be read and sometimes resetting it can help to cure the problem - sometimes temporarily
I read on another page (Honest John) that the fuses should be checked first for damp/contact problems.
Is there actually an EPS fuse on the k12? If so, where is it located in the fuse box?
I also wanted to ask for a recommendation for a cheap code reader for these cars which can cancel the EPS faults (an maybe code in a new one)
I have read that the unit can be reconditioned.
Does anybody actually know what the problem with the EPS does be? Is it usually a fault in the motor windings or something like a contact problem or is it an electronic problem?
If the car's own unit is reconditioned, I take it that it does not needed to be coded in upon refitting?
thanks
thanks
