cam cover bolts - 3Nm - 2 lbf ft
crank pulley bolt - 142Nm - 105 lbf ft
timing chain tensioner bolts (upper and lower) - 7Nm - 5 lbf ft
cyl head cam sprocket access cover nuts/bolts - 5Nm - 4 lbf ft
timing chain idler sprocket center bolt - 51Nm - 38 lbf ft
cam sprockets retaining bolts - 113Nm - 83 lbf ft
cam bearing cap bolts - stage 1....2Nm - 1.5 lbf ft
stage 2....6Nm - 4 lbf ft
stage 3....11Nm - 8 lbf ft
cyl head bolts (main) - stage 1....39Nm - 29 lbf ft
stage 2....78Nm - 58 lbf ft
fully slacken all bolts, then tighten to stage 3....35Nm - 26 lbf ft
stage 4....angle tighten 60 degrees
cyl head bolts (6mm) - 7Nm - 5 lbf ft
big end bearing cap nuts - stage 1....15Nm - 11 lbf ft
stage 2....angle tighten through 45 - 50 degrees
main bearing cap beam bolts - stage 1....28Nm - 21 lbf ft
stage 2....angle tighten through 60 - 65 degrees
