I'm thinking of swapping my power steering pump out for an electric pump. Not a complete electric system but instead run my hydraulic system with an electric pump. It seems that a few non micras (106/saxo/MR2 for example) have had this system installed as standard so won't cost the earth. I've built an engine on a every little helps approach so I'm also adopting it here for all those loses!
My question is tho how does the pump know when to pump? Sounds stupid I know but would I need to install something to measure angular displacement or torque wired to a relay rather than a direct ignition feed to the pump. This I guess is where it gets difficult as presumably my micra won't have anything like that fitted?! And don't really want to start cutting and shutting other racks to fit.
I think @Jordan27 has done something similar before?! (apologies for the tag if you haven't!) But I can't find much info about it here.
PS don't turn this into a debate on pro's and con's of power steering!!
