Electrical trouble won't start????
CMF_Tone
Hi,
Looking for elec help with wifes 94 Micra 120,000km. Had misfire on one pod, chased down to water in plug hole so gapped and cleaned all plugs. Will admit spanner touched bat +ve and A/C pipe *sparked* a little.
Went to start after service and only noise was clicking from fuel pump relay, behind drivers kick plate, when ignition on and all ignition and interior lights fade like a flat battery or major current draw. No cranking at all from engine, Pulled fuel pump to check and it is fine, spins well.
Removed fuel pump fuse and relay tried cracking, still same light fade trouble once ign is turned on lights OK if left on Acc??
Have checked all fuses in engine bay and drivers compartment all OK??
Any suggestions greatly appreciated.
CMF_Tone
xero,
Thanks, sounds to simple battery removed and jumped to terminals from another hey presto cranked away. One new battery later and all is well includng no more missfire.
