K10
Hi Folks,
I have a problem with my micra- when I pull the keys out of the ignition, the ignition lights come on :down: and the battery is draining when not in use.
I had a similar fault on my old classic escort, which was the regulator causing the exact same fault. Does anyone think it could be the same thing?
Also just to point out, since having a new windscreen fitted, it leaks in the corners letting in wet, and cos the weather is so poor I have had no time to seal it up yet. Does anyone think damp could be causing a short inside the cabin? The water seeps in at the bottom left and right hand corners of the screen.
Any help appreciated
Cheers, Dan
Cheers, Dan
