Hi guys,
my misses has got a classic mini and she wanna wire in some extra accessories. She wants a cigarette lighter as well as little electrical heater.
I will create little facia with some switches as well as the lighter.
I will feed this fused straight from the battery to make sure the wiring is ok.
I need to feed this to junction box that only comes on with ignition on only, so when she forgets to switch this off, and she will, it wont drain the battery.
Is there some sort of relay that will act like on/off switch operated by the ignition?
thank you
thank you
