Kamarley
If it aint Jap its Crap!
http://bit.ly/16NcdLW will this work and is it a reasonable price??
That kit looks pretty damn kool! Must say might be easier to fit the original micra kit but sources one might not be as easy?
Have you been watching mighty car modshttp://bit.ly/16NcdLW will this work and is it a reasonable price??
SuLuR, it is easier with the original micra regulators but the kit is seriously a bad move, if its a temprary thing then be it cos there realy not worththe time, as says a while ago, i was an auto electrician and i fitted toms of these as customers brought them to me and i advised them not to fit.. so i did, one scenario - it was raining and window did not work, motor overheated and failed, the thermal switch in the motor melted which is the overload switch..... the only window kit i would use is made by BERU but are hard to find....
J
Scott.c said:Have you been watching mighty car mods
I don't even know what goes into a full genuine set and how much I would need and how it comes apart or how to convert the manual wonder to the auto and most importantly how to wire it up
I had winder windows in my old micra, and my current one has electric windows. I considering converting mine to manual windows for a few reasons 1)less to go wrong 2) I have some fancy alloy winders that i cant fit 3) manual ones are make the car a fair bit lighter without the motors 4) personaly, i prefer oldskool winders 5) when the windows are frozen up and you flick the switch it pretty much instantly pulls the runners off the bottom of the windows ( i currently have no windows i can put down untill i fix them both!), with manual ones when you feel the resistance, you stop.
I know its all down t individual choice, but personaly from my experience, id choose manual windows over electric ones.
once you get hold of em' pm me and I'll remove the door cards for you and snap some shots, but be advised I'm no pro DIY, I head for functionality most of all..Thanks for the info bro I don't think I have to worry about the heat in the UK will be ordering a set when I get some spare money as project micra has Been put on the shelf for a while
funky2nite said:once you get hold of em' pm me and I'll remove the door cards for you and snap some shots, but be advised I'm no pro DIY, I head for functionality most of all..
Cheers,
Ian
Easy job refitting the windows....... use double sided carpet tape in the runner and they will stick forever....they have for me through rain and ice, frozen windows and so on.I had winder windows in my old micra, and my current one has electric windows. I considering converting mine to manual windows for a few reasons 1)less to go wrong 2) I have some fancy alloy winders that i cant fit 3) manual ones are make the car a fair bit lighter without the motors 4) personaly, i prefer oldskool winders 5) when the windows are frozen up and you flick the switch it pretty much instantly pulls the runners off the bottom of the windows ( i currently have no windows i can put down untill i fix them both!), with manual ones when you feel the resistance, you stop.
Also if your runners are a bit dry.....use candle wax to lube them...better than wd40 and should last a long time.
Happy fitting...takes about 10/15 mins.
