hi all got a problem with my 1.2s 2005, the passenger electric window switch will not work on the drivers side,the window works normaly on the passenger switch, any ideas?
you could try getting holdof a new switch from a scrap yard or use a multi meter to see if there is voltage coming to the switch, in which case u wud know its a faulty switch if not could be the wiring or the motor.
