Put one on a supercharged small block chev. Worked.....ok.
The pump failed on a run one day at the worst place and time possible. Sunday afternoon on the way back from Canberra.
If I had a normal pump it may have been a quick fix with a belt (spare in the boot) or a standard pump from a speed shop
repco worst case)
The choice to run an electric water pump might save you some power, but it could cost you something more. Nothing's free in the power-building world. What makes power for you in one area, can extract a price in another. While the power benefits of an electric water pump can hardly be denied, the costs of running one on the street can be harsh. Overheating would be your main cause for concern. That's because, while most stock and aftermarket belt-driven pumps can flow as much as 400 litres of water per minute and racing pumps can flow even more, most electric pumps flow less than half that amount. It's a simple matter of physics and a giant paradox of performance. In order to flow enough water through the system, the pump requires a power source strong enough to move a large quantity of liquid. The gains from moving lots of water through the system are better cooling. The losses are measured in horsepower. An electric motor, on the other hand, does not cost horsepower to run, but instead it trades volume for power and cannot flow as much water.
The eventual benefits of the electric pump...to me, were small.
The hassles it caused setting up etc etc for whatever gain I may have recieved in power in the long run wasn't worth it.
Eventually thge hassle of changing back to mechanical unit was well worth it (because of the blower)as I had trouble free motoring from then on.
