dg_unit
Club Member (Trial)
I need advise on the best way to wire in my remote central locking unit. Should I mess around sending new wires directly to the battery (which will be a nightmare trying to get it through the pokey little hole and rubbers where the main loom goes) or is there an easier way like using the wires that come into the ignition switch? The wires to the unit are fused so I don't need to go through the fuse box.
Obv the locking unit will be draining a bit of power at all times but I want to avoid wiring it so the battery keeps running flat. I've heard this is possible.
Hopefully will get it finished this afternoon :grinning:
