ecu
CMF_frank2
jody
iirc, the uk spec ones had nats 1 (with a 2 button fob) from about 95, then nats 2 (with a red chip in the key) at 96 ish onwards, and the loom is wired differently.
and apparently the 1.0 ecu has a bit more ignition advance, but otherwise has the same map (re micra_pete)
frank
