Hi can any one tell me if they've had this problem with there micra. power and fuel going to the injectors but all four injectors not pulsing so wont start could it be a ECU problem. IF it is the ecu can I just get a second hand one and would it be a case of plug in and go or dose it need to be programed to the car . Also be for it conked out altogether it was cutting out as you drive it it as if the key s being turn on and off very jerky then it will be ok for 30 seconds then do it again. Its had new ht leads distributor cap points coil. im sure its an electrical problem because its intermittent Any help would be appreciated
