Blue
Hi
Ive got a fault on the car a 1.0l t reg micra where it runs sweet when cold but when the engine warms i get kangarooing lag from the throttle and if i let the revs fall below 1000 the engine will cut out especialy if i brake. im looking for the diagnostic kit to check the ECU as the garages ive tried havent got the connector for the ECU ive replaced
sparks
fuel filter
Throttle Boddy
dizzy rotor arm and cap
and the same problem still persists ( but the car feels like new).... for ten minutes
im going to replace the lambda and the temperature sensor under the dizzy.
Is there a secondary lambda probe as ive red in the haynes and if there is where is it on the car
thanks
sparks
fuel filter
Throttle Boddy
thanks
