I am going to apply turbo my cay. But I do not know the suitable ECU. Can you help me? Do you know where is the turbo oil output and input on the engine?
ask whoever is going to tune it as to what ecu to run. for the oil drain from the turbo you'll need to pull the sump off and weld a fitting onto it.. oil pickup can be used from the head above the alternator (gay) or tee'd off your stock oil pressure sender (wicked)
