B
bal
hi
i have seen these chips/resistors on ebay and basically they promise a 20bhp power this seems too good to be true
here is a quote from the auction
The mod itself is a small resistor that tells your engine control unit (ECU) that all of the air coming into the engine is cold and therefore dense and packed with oxygen. The ECU then takes this info and tells the injectors to fuel slightly more. This in turn makes for a more powerful detonation in the cylinders and releases the full potential of your engine. Since the altered signal will always stay within the manufacturer's specifications, there is no way for your engine to get damaged in any way.
is any of this true?
this particular auction was £2 in total but before i buy i was wondering could it cause any long term or serious harm to my engine if i make it run like this for the rest of its life?
should i buy it and only use it now and again when i want?
the auction says it is easy to install and quick to remove but i dont know what to beleive from these poeple
any advice or guidence would be much appreciated
