Drivers Side window
CMF_Mark
My window has stopped moving. When I turn the handle I can feel the movement, Is something likely to be broken or will it have slipped off a guider?
Any hints before I dismantle the door panel.
CMF_Napster
im not realy sure about this, but if u "unscrew" the "door handle", then "pull" at the door sill it will pop off. i should be able to make a judgment at wot is it.
sorry for not knowing to much, but might help!?!?
sorry
napster
CMF_daily_ricer
Not 100% sure what the micra winder is like, but my previous cars there is a metal "u" shaped clip that holds the winder on. You got to put your hand between the winder and the interior door trim to be able to see it then put a flat head screw driver in there and pry it off... its abit hard to explain, but if you have a look it will make sence.
The hard part is getting the u clip back on. Also make sure you cover the winder with your hand or something, its likely to spring off across the garage only to be found again six months later.
