Hi, (my first message
My drivers door would not open from the interior handle today, after some Googling, turns out the front doors use similar locks as the rear & have a child lock
also. This has no exterior switch & is hidden in the door frame. Remove the 3 screws holding the lock, raise the lock up & on the lower part of the lock (the side that closes on the door seal, you'll see a small switch/slot, using a small screwdriver lift the switch & viola! its working again.
I would recommend (carefully) putting a small blob of adhesive to stop the switch from dropping down again, in the future.
Hopefully this will help someone else.
